wire amp to 91' Buick
What three wires ? Power, ground , and remote ?
Power goes to a twelve power source. preferably the battery.
Ground to a paint, and rust free metal spot.
Remote if nothing else to a acc. lead in the fuse panel that only gets power when the ignition is turned on. Or you could simply wire a switch in place. And run a 12v source to the switch, and then to the amp. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I have a +12v screw, a ground screw but where does the REM wire go? my freind said it went to a blue wire from the stereo system but I hav e the factory tape player in mine and he said it probably didn't have the blue wire.
What did you hook the remote wire to ?
And the power wire ?
and the ground ?
Let me know and hopefully we can see where the problem is //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It works now. My ground wasn't good enough. I have my power wired to the + batt. terminal, the REM to a fuse in my fuse box and the ground to part of the chassis outside the driver door.
yeah, it'll be hot but off. Just like your tv when it's plugged in.
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
EMR sniffer or AM/FM sniffer. small radio but with a probe antenna to it. It gives you the specific location on the ground loops. This device...
26
I agree…not a very good install. Hopefully you didn’t pay much (hopefully it was free). Get your DMM (or find someone who has one) and find a...
Soul_Man
Soul_Man
Salmon, ID
Soul_Man
