WinISD questions
  • 3
terifi
your average stereo junky
downloaded WinISD, and filled in most of the info, however, i could not find the variables....
What does Z stand for, it wants ohm units, but what is it?
SPL?, wants decibels
PE?, wants watts
also for Xmax, and Diameter does it want Meters, b/c i am only given mm on my sheet, so i move the decimal 4 places to the right? so for xmax it should be like .001191 b/c it gives me 11.91mm?
Originally posted by terifi downloaded WinISD, and filled in most of the info, however, i could not find the variables....
PE?, wants watts
The measurement in WInISD can be changed by clicking on it.. if it's 11.91mm, then change the required measurement by just clicking on the m, cm, mm, ft, yd, in, whatever...
Originally posted by Jmac You should use WinISD Pro ... WinISD is a waste of time :p
But WInISD pro is still an alpha version isn't it? I eman, it's not yet complete or something... guess I'll try to look for it right now...
Originally posted by Jmac The only thing it's missing is the ability to get a print out of the numbers //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Pro is still much better, even though it's a first edition ...
ah~~~~
thanks again, O wise one:)
Originally posted by terifi Thanks, but anything about Z, SPL, or PE?
z= the speaker ohm (or was that nominal ohm's)//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
SPL refers to the sensitivity of the speaker eg.: 89Db, 92Db (or was that SN/ratio or dB @1w/1m?)//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
and PE is the operating power ( was that RMS or peak)?
Jmac, please clear this up for us..//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif hehe...
Originally posted by Jmac Z = Nominal resistance
SPL = Sensitivity (1 W @ 1 M, not 2.83 V @ 1 M)
PE = Thermal Power handling
J,
about the PE... the ROckford technical data sheet states both RMS and peak for operating power (PE) and in winisd, I've always used the RMS to be safe...
what do you recommend? would it matter a great deal if these numbers change?
You have to know the signs for winisd. IMO, it really comes down to knowing what you’re doing. Some woofers don’t model well in winisd, at all.
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
347
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
Thanks for the reply bass addict. I am sure with ya'lls help I'll get it tuned up. Audiobaun has been a huge help. He basically linked everything...
50
5K
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
8
989
terifi
terifi
North Carolina
paikiah
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
