Winisd help?
that shouldnt happen mines defaulted into a ported for the sundown X 12
Are you sure you are entering the units of measurements matching to what the site specs say? Like vas in liters, MMs in grams, BL in N/A
I'll try AGAIN...LOL!
As I was entering Mms and Cms the autocalculate put the Fs at 1137.63 hz... I stopped here and say that I did correct this to 36.1 hz one time and it made no difference either way...
Should I proceed?
Should I proceed?
DUDE LOL REFER TO POST 51. Go from left to right, top to bottom. You are entering everything in the wrong order.
Why would you even care about cms when i told you the most important ones are the Q figures, VAS and FS.
OK.. I started on top and let the tab advance the fields... left to right, top to bottom... I hope I did it correctly... and I got this!...
you forced the QTS and didnt let it autocalculate. You FORGOT TO HIT TAB the most basic rule. watch the youtube tutorial. JUST WATCH IT
I started entering and stopped... I will not go further but I don't see an autocalculation... is it coming if I enter more values further down the list?...
OK.. got a little farther down the list but I decided to stop as the auto-calculate came up with 59.9 for the Cms and Sundown lists .06... is the autocalculation OK?
---------- Post added at 09:51 PM ---------- Previous post was at 09:50 PM ----------
watch the youtube video i linked please.
Will do..
Will do..
cms doesnt matter at all. it can be zero and you'll still get the same graph, it makes zero difference. If its not the big 5 dont give a rat's @ss about it. Technically you can just save the driver and work off what you have right there already and it wont matter if you enter in the rest or leave it empty.
After all that I just proved what an idiot I can be!... LOL!.. Thanks for demanding that I watch the YouTube video... Success!..
shredder1
shredder1
AZ
Papermaker85
BP1Fanatic
BP1Fanatic
