Will this set-up work and.......
Pope1605
Utah
Hello,
Just got my tax returns, and now I wish to upgrade my audio system in my car. The car is a 2001 Chevy Cavalier 4 door Sedan. I am looking to spend about $600 on deck, 2 10" subs, and an amp. So far I have came up with this set-up, but since I have only upgraded a system once, I need your expertese in telling me if this will work. Any set-ups will be greatly appreciated.
Panasonic CQ-DF802U 50x4 (200 watts) (Deck)
Total Power (Max.) 50W x 4 (200W)
MOS-FET Output Stage Yes
Super High Definition Bass (S-HDB) Yes
Preamp-out (RCA) Front / Rear
AUX Input Yes
Bass/Treble, Balance, Fader Yes
Loudness(L), Muting(M)/Attenuator(A) M/A
Frequency Response (±1dB) CD: 20Hz - 20kHz
AM/FM Stereo Radio 50dB Quieting Sensitivity (75 ohms): 15.2dBf (1.6µV)
S/N Ratio CD: 95dB
FM mono: 60dB
THD (1kHz) 0.02%
Channel Separation (1kHz) 70dB
4-Channel High Power Amp Yes
CD Changer Control Track/Disc Scan, Track/Disc Repeat, Search, Random Play
Built-in Quartz Clock Yes
Flashing Warning Light Yes
Illumination Color Blue
Open Face Access CD
Wireless Remote Control Included
Removable Faceplate Yes
Spectrum Analyzer Yes
Super Bright Display with Dimmer Yes
1-bit D/A Converter (CD Player) Yes
Anti-Shock Memory & Floating Mechanism CD Player
Digital Servo Optical Control (CD Player) Yes
Hologram Pickup (CD Player) Yes
Multi-Stage Noise Shaping (CD Player) Yes
One-Chip Digital Circuit (CD Player) Yes
Oversampling (Digital Filter): 8x (CD Player) Yes
/CD-R/RW Playback
Track Scan, Search, Repeat, Random Play (CD Player) Yes
18 FM/6 AM Presets Yes
Adaptive FM Front End (AFE) Yes
Alphatuner V Yes
Auto Preset Memory Yes
FM Optimizer (FMO) Yes
Impulse Noise Quieting (INQ) Yes
Preset Scan Yes
Subwoofer Output Level/Impedance: 5V/60 ohms
LPF Frequency: 80/120Hz
Preamp Output Level/Impedance: 5V/60 ohms
Speaker Impedance 4 - 8 ohms
Pause Yes
Dimensions (H x W x D) 115/16" x 7" x 57/8"
JBL BP300.1 Amp
Output 4 Ohms: 150W x 1
Output 2 Ohms: 300W x 1
Signal-to-Noise (dBA): >100
Frequency Response (±3dB): 20Hz - 500Hz
Total Harmonic Distortion: 0.1%
Input Sensitivity: 250mV - 4V
Die-cast chassis uses the entire footprint for amplifier cooling
"Direct-Connect" allows choice of 4 - 8-gauge power and ground cable
High-frequency switching power supply is more efficient, drawing far less current from the vehicle's electrical system
Four high-level and low-level inputs facilitate constant bass, regardless of head unit fader position
Variable electronic crossover and bass-boost optimize subwoofer performance
AUDIOBAHN ABP10 DUAL SUB BOX W/ 2 10"
High Quality MDF Construction
Spun Aluminum Venturi Ports
Durable Gray Carpeting
½" Plexiglas Window
Interior Neon Lighting
Mirrored Interior Panels
Dual 10" Molded, Texture Injected Poly Cone
50 oz. Strontium Magnet
2" 4 Layer ASV Voice Coil
Bumped Back Plate
Extended & Vented Pole Piece
Gold Binding Post Terminals
Power Handling: 600 Watts RMS
Sensitivity: 101dB
Frequency Response: 30Hz - 150Hz
That should be a decent setup for the price range your looking at. I would suggest maybe getting the jbl 600.1 It can be had for like $50 more then the 300 and you would have room to upgrade later on if you wanted.
Pope1605
Pope1605
Utah
RMKrider1
michigan born
    May 14, 2026
michigan born
    May 14, 2026
