Will most 1 ohm stable amps...
Sleeklsc
Handle a .67 ohm load? It's actually .85-.9ohm once measure out on the dmm. The only 1 ohm amp i've ever ran at .67 is my present PA a2400db on 3 Type R's, and that ended up sitting exactly @ 1 iirc. Handled it fine.
I'm now using 3 d4 JBL gt5's (so far so good), but i'm thinking about getting a higher quality amp.. I'm doing it moreso because it's easier to get power that low vs 2.67.
at .8 or .9 you should be good but .67 may be pushing it a bit.
It also depends on the quality of teh amp and how much power you are sending to it as well.
at .8 or .9 you should be good but .67 may be pushing it a bit.It also depends on the quality of teh amp and how much power you are sending to it as well.
Well I highly doubt i'll ever be sending them anything over 1200rms. And if I do it doesn't usually last long. Being so close to one ohm makes me think it'll be ok.
Sleeklsc
Sleeklsc
tc300
