Will most 1 ohm stable amps...
Sleeklsc
Handle a .67 ohm load? It's actually .85-.9ohm once measure out on the dmm. The only 1 ohm amp i've ever ran at .67 is my present PA a2400db on 3 Type R's, and that ended up sitting exactly @ 1 iirc. Handled it fine.
I'm now using 3 d4 JBL gt5's (so far so good), but i'm thinking about getting a higher quality amp.. I'm doing it moreso because it's easier to get power that low vs 2.67.
at .8 or .9 you should be good but .67 may be pushing it a bit.
It also depends on the quality of teh amp and how much power you are sending to it as well.
I've done it with a few Zenon amps. They'll drive half an ohm, but keep in mind, low impedance is terribly rough on semiconductors no matter how "good" the amp is.
at .8 or .9 you should be good but .67 may be pushing it a bit.It also depends on the quality of teh amp and how much power you are sending to it as well.
Well I highly doubt i'll ever be sending them anything over 1200rms. And if I do it doesn't usually last long. Being so close to one ohm makes me think it'll be ok.
Ive ran my mmats dhcx2200.1 below 1ohm. .7 and with box rise was around 1ohm I think.. It's been awhile can't remember the whole scenario. Lol.
It also lowers the amps efficiency and raises the current draw.
646
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
438
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
Sleeklsc
Sleeklsc
tc300
