I used to be very opposed to the idea of using CCA. Recently I've been working in Industrial Services. I have been doing a lot of electrical work. Over the past 9 months or so I have learned that the only reason to use OFC is to save space. We use aluminum wire everywhere we can. It requires more runs, but accomplishes the same thing. CCA is great. It's lighter and cheaper. If your application limits the number or size of the wiring then clearly OFC is more efficient, but otherwise I would never pay for OFC just to have it. As long as you know the amperage being pulled through the wire and it is within what the wire is rated for over the given distance you will be fine. There is no downside to using CCA save for the size difference.
