You guys should watch this. Why do people even use CCA? Other than pretending to have the right size wire I don't see the point. IIRC, a single run of 0 gauge CCA can only handle as much current as a single run of 4 gauge OFC.
Do it right the first time. Assuming your system requires runs of 0, you'll end up buying it down the road anyway once you realize your voltage is dropping / fuses blowing.
4 gauge OFC is cheaper per foot than 1/0 CCA anyway (According to KnuKoncepz).
