Why is my voltage drop so awful?
You shouldn't have ANY voltage drop across the system. It should all be the same. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Id take all your connections apart and sand the mating surfaces to make sure youre getting the best contact possible
All ground points have been sanded, brohamsandwich //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
change all your 4 awg in your whole set up from bumper to bumper with 1/0 or 0 awg
and it will be better i can assure you
and always run your system with the car on
so buy $100 worth of wire, spend and afternoon with your friends talking smack and swapping wire
and it will be fixed
....if you assume no resistance in the wire, this is never the case tho, all wire has some sort of resistance no matter the size, length or material, though it may be minuscule.
//content.invisioncic.com/y282845/emoticons/applause.gif.bb805d8088f72dbc2fe808c29e85fb4c.gif:applause://content.invisioncic.com/y282845/emoticons/applause.gif.bb805d8088f72dbc2fe808c29e85fb4c.gif:applause://content.invisioncic.com/y282845/emoticons/applause.gif.bb805d8088f72dbc2fe808c29e85fb4c.gif:applause:
I have 1/0 front to back, just 4 to the amp after the distro.
You're right, but nevermind.
There is obviously high resistance between the rear batt and the amp. If you're dropping .2 and there is no current being drawn, that is bad. In a parallel circuit the voltage should be the same. It's only once you start drawing current that the resistance of the wire should become evident. You need to either shorten the run from the back batt to the amp, or shorten the ground or both... or tighten something. It's right there. It can't be anything else.
hatedonmostly
throwin' hunnits, hunnits
hatedonmostly
Detroit, MI
osl
