Why is my voltage drop so awful?
You need to listen to people and ground your rear battery somewhere else. The bed of a truck is not a good ground. Many people (such as yourself) fail to realize how important the ground is in a car electrical system. I really think this will solve the problem of the voltage difference.
Oh, I realize how important it is...but logically, if I'm not seeing any difference in voltage between the front and rear batteries, I'd think it should be a good ground. I've posted that multiple times, and no one has said anything about it being right or wrong. I'm not just trying to solve the problem, but I also want to understand it too...
I do believe that is my remaining option, so tomorrow I'll be up early to try that...
I have had seemingly "good" grounds that were actually terrible. Change your rear ground and test the resistance between that point and your front battery's negative terminal.
It would be best to grab some more wire and run it all the way to the front batt to avoid all of these issues.
Eventually I will, if this works.
They don't charge to 14.4v. They charge to around 12.6-12.8v. They can float up to 13's, but they rest and discharge most of their current at 12.6-12.8v. So, since they do basically nothing above 12.6v, I again ask how could batts help above 12.6v?
I don't understand this...
Moving it to the frame could be the difference.
I'm kinda skeptical about it being the cure-all for all of my problems, but it's all I have left to try...
Then what don't you understand about batts don't charge to 14.4v?
Shit, my bad. I know the batteries themselves do not charge to 14.4v, but the charging system runs at 14.4. A bit of miscommunication there...
So basically, if you don't have a HO alt up front, no matter how much reserve you have in the rear, you're always going to have voltage drop?
hatedonmostly
throwin' hunnits, hunnits
hatedonmostly
Detroit, MI
osl
