xSPLoder
o_0
That would be my first place to start.It should be wired to 3 ohms
I wonder if they wired it to 6 ohms that would explain a lot of my power issues.
Well I have a dmm but I lost the manual , what setting do I test ohms on?That would be my first place to start.
Well I'm guessing they will take it back as it was installed at their shop by their head guy ...who even said after himself the alpine was louder , I'd rather get this amp working tho , since it a nice amp and will be future upgrade ready.Can you return the amp to the shop? I'm guessing you'll have to eat the labor charges.... That's why independent Mom and Pop shops get a bad name. See someone like you coming and take complete advantage. Sorry man. I'd return the amp and cut your losses.
if it is this^^..I am curious which side is louder, right or left?..lolJust go out to your car and pull an RCA out, it only takes a second. And if it doesn't work, then you know you have some testing ahead. If it does work, the problem solved.
That means that one of the rcas was wired backwards so when the signals from both rcas were combined, the signal was getting cancelled outtry this , pull one of the rca's from the amp and see if it gets louder ,i had 2 of these and when i run just 1 rca to it it was waaay louder.dont know why just was .
This still would do a lot more power than the alpine , it does 2500 @1 sure but @ 3 its still getting well over 1k and sounds like its getting 300 rmsThe alpine was rated at 2 ohms. I'm guessing your new amp does rated at 1. Running at 3 ohms means your getting ~1/3 power.
