Which woofer?
well shit, tom and i figured out he was just trolling as he claimed to be 15, yet registered in 2011. after bombarding him with an excess of questions taking up tom's time in his alignment service thread and never committing to a service, the ban was well deserved after he stated going in a completely different direction and taking on someone else's service.
btw, kingchonky is an anagram for honkyg nick,... someone who uses his 'nudels'. lmao
oh snap! You got me!! I would have never guessed.
Yeah I gave him ****(maniac) for posting in the wrong section.
it was most likely blatant with as many times as he mis-posted.
im one hell of a master of disguise, only tom was able to figure it out right away when i registered as k/c.
Kicker amps aren't 1 ohm stable, but I see that link provided they're changing things a bit. Since it says avail soon, and will cost a lot.
If I were you, I'd try and get the AQ 2200.1 Can be had between 200-350.
If I go with the sundown x and get a 2k+ amp what kind of electrical will I need. I have some electrical done but not sure if it's enough.
Stock alt 150amps
Big 3 done
Xs power d2400 underhood.
Will run the amp with 0 gauge. Is that enough or can I should I get a small xs power xp for the back?
What is your budget?
Stock alt 150amps
Big 3 done
that is an Ideal crossover and designed for use in an home type loudspeaker. A simple Linkwitz-riley 2-way is easy enough/ The tweeter wire lead...
36
Those subs are 400w RMS each, and that dual enclosure is 800w RMS with a 2ohm load. That's a 4ch amp that does 55w x 4 @ 4ohm, & 75w x 4 @ 2ohm...
867
  • Locked
Looks familiar: https://www.caraudio.com/threads/who-needs-new-equipment.613325/ Wouldn't that be a real kick in the ass. I shared that so...
And dont skimp on the Sql...that doesnt mean it dont get loud,that just means it sounds great while getting loud lol
Well yes, I've searched cruthfield many times, I just wanted input from actual people to go off of instead of numbers and prices. I've got it...
Supratt07
Supratt07
Los Angeles, CA
Boomin_tahoe
