Which sub would be better??
The hds2 is the way to go I have run 1k daily on the hds212 with great results . I love sd stuff but on your budget sq is the way to go.. I have run both the eseries and the hds2 and they both sound great but the hds2 will take a lil more power.. Sq gets the nod on this one hands down
Sounds like Im going with the SQ then.. Do you guys happen to know the box specs? I havent been able to find them
If it were me, yes I would get the hds3 series. That way you can upgrade power someday.
As for the enclosure, I'd message sound qubed and ask but 2 to 2.5 cubes tuned around 35 is what they recommend.
I migh aswell upgrade to the hds3 series then. So they both basically need the same box, I was thinking around 2.5 tuned to 32 or 33
Ditto '
Always buy over what you need if you can!!! That way when you run accross that "I cant live without it amp" your good or....closer to good
Isnt the Dcon more of a sealed sub? I already have a ported box
I would definitely go with the SoundQubed sub. You get the most bang for your buck from them.
Its been a while since you posted on the thread? Did something happen?
also, A properly powered HDS3 in 2.5cu feet hits hard. Trust me! Its my setup lol and its definitely a budget system if you look at the big picture!
ThinnestShark11
Porterville, CA
denim
