Which Sub HELP!
okay guys i appreciate the help what if i sold my amp and subs and started fresh if i wanted a re xxx 12 what amp would you recomend and what size sealed box. and how much louder or more bass would it have than the re se 12
Much more bass than the SE in correct ported enclosure. But you look like you want all out bass. If you can affort it a XXX 15. Its run about 450 shipped. On a budget: if i say audiobahn amps i know im gonna get 10 dudes frontin on me. So lets pretend i didnt say that.
Start fresh, this way you wont be dissapointed
actually come to think of it. i think u better go with the xxx 12. I dont think anyone is ever satisfied with their system in the long run, and you will be looking for an up grade within a year.
I assume this is your second setup, so dont go all out just yet. The 12 is just fine. I know you want Bumpin bass, I'll recomend the JBL. bp1200.1 amp, it will run you 260-280
(1200rms) hook that up to the XXX. This setup will make strange things move in your car. you're lookin at 600 bucks to get this goin. Some one set this dude up with a ported enclosure that will get that xxx12 up there on the meter
sealed is fine, you ll get better sq and it will still BUMP. And if you re not satisfied with sealed you could alwayz change the box easily. so dont worry much about the enclosure just yet
order the SUB AND AMP first.
gto series are no good. I garantee you will love the JBL bp 1200.1. Its **** LOUD. 1 ohm stable( most high end subs need to be run by amps that are 1 ohm stable). And if u got that hooked up to a XXX. you're gonna be poundin.
Ask around about it just to assure yourself that its a beast. U should be able to find it for about 260-280 bucks.
Srt2fast4u
Srt2fast4u
ct
Norcalracer283
michigan born
    May 14, 2026
michigan born
    May 14, 2026
