which sub best fit for 1500rms ALL DAY LONG?
pinoywitboom
hey guys well been doing researching and have come to the following options. i will be running 1500rms daily or to make it clear as possible ALL DAY LONG. now my question is which of the following subs will soak up 1500rms ALL DAY LONG or as long as i can put it out without NO mechanical inefficiencies or thermal inefficiencies? or basically no vc burning when da pressure is put to it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif my options are:
1. fi bl
2. re mx
3. sundown nightshade
4. dd 3500
since these are as close to eachother in prices brand new (i think) i thought these would be some prime choices for what im looking for. also this time around i have really no care sq wise as loudness is wat im looking for now. so which sub would rise above the rest when faced head to head when it comes to spl? also the subs needs to be able to perform the LOWZ exceptionally and no half assing on it, cuz i luv dem LOWZ //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif so which sub will get lowest and loudest and not stink while doing it ALL DAY LONG? thx for the help!
You described RMS ratings in your first paragraph. Start there, DD 3500 won't make it, it rates at 1200 watts. For an all day setup, I'd rather use multiple subs vs full power. That would be easier on your batteries, amps and subs.
You do realize that even with the amp gains set correctly, as soon as you start playing music, you're not running continuous power, right? 1200 rms rating on a 1500rms amp playing MUSIC will not have a problem at all. Hell, I've run 2x rated power on music with gains set correctly without a problem. The RMS rating is continuous power and music is nowhere near continuous.
Mechanical power handling is entirely dependant on the box.
pinoywitboom
pinoywitboom
Da Big Isle
Coolwazabi
