Which should I go with?
wagz125
I'm looking for a system to enjoy the performance, clarity of my music, not just loud bass. I'm stuck between getting this sub woofer that has an amp built in http://www.crutchfield.com/App/Product/Item/Main.aspx?g=51000&i=500PLT5&tp=114
or this that I would need to get a seperate amp with but is cheaper
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=510&i=236RT12X2A&tp=112&tab=features_and_specs
with this amp
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=120&i=489HA700M&tp=115
which would be easier to install, would the performance be that different?
I'm new to all this so all feedback and help is appreciated!
BTW i drive a 1991 Honda CRX so it is a pretty small cabin.
Any reccomandations? I figure id need a mono amp, and a 4 channel amp because 5 channel amps are expensive!!
Oh you are getting speakers as well?
Whats your budget.
And that sub has an amp built in so you would still technically be running two amps
If you are going to be getting an amp to power them then id go with componenet speakers.
alright thanks for all your help. I think im going to get components for the rear, and the ones i posted above for the front, not sure about amp and sub yet
PG RSd65cs 6.5" components speakers about $90 shipped (http://www.audiosavings.com).
2 RE Audio RE10 or RE12 subwoofers, about $120-$140 shipped for both (http://www.audiosavings.com), plus a box ($100?)
Hifonics BXi606 600w x 1 @ 1 ohm subwoofer amp, $130 from http://www.millionbuy.com
Hifonics TXi6008 150w x 2 @ 4 ohm component speaker amp, $140 from http://www.millionbuy.com
That comes to about $600. That leaves a little for wiring. http://www.knukonceptz.com has good, inexpensive wiring kits.
wagz125
wagz125
Columbus, Ohio
darkhunter139
michigan born
    May 14, 2026
michigan born
    May 14, 2026
