2008screw
Hey all,
I am bridging my amp to a set of comps. Not sure which setting I should set the amp to? The amp is an Alpine PDX-4.150
Input Channel Selector Switch
a) Setting this switch to “1 + 3/ 2 + 4” will sum
the CH-1 and CH-3 input and send it to
CH-3 while the CH-2 and CH-4 inputs are
summed and sent to CH-4.
b) Set this switch to “3/4” to have the inputs of
CH-3/4 accept independent input signals.
An example of this application would be
the use of a head unit with dual pre-amp
outputs.
c) Setting this switch to “1/2” will send the signal
at the inputs of CH-1/2 to CH-3/4 of the
PDX-4.150. This eliminates the need for
“Y”-adaptors when using a head unit with
a single pair of pre-amp output.
outputs.
