rockford amp any good?
rob_z89
i just got this today and just wondering if its worth keeping it was made in 89 if i recall
you know if all it really puts out is 75 watts i was wanting to run some cvr 8's off of it but i dont think 75 will cut it
Those are waaaaay underrated.
Its probably closer to 120w per channel @ 4ohms.
Those used to be the amp to use on subs back in the late 80's for many people.
It will do fine on your 8's.
so then its worth keeping i guess
not bad for 30 dollars then hope it will do good for what i need
anyone know if it can handle a 2 ohm load bridged?
well most likely ill be wiring this up friday when i have a chance and go from there hopefully it will work good in my application if not ill put it up for sale
I don't think you can run it 2 ohm mono, 2 ohm stereo - yes.
Keep it at 4 ohm mono if possible. Running it a 2 ohm you will have grill to cook hamburgers and hot dogs on in the back of your car if it does not blow up first.
alright thanks for the info i think imma try at 2 ohms for a few minutes and see how it does if not i can just re wire it to 4 ohms with my other subs
rob_z89
rob_z89
san pedro,ca
USCFAN
