Which set of 12s would be better? Jl w3v3 12 or dd audio 1100 series 12?
Depends on what you're trying to accomplish. For ported/sql enclosures, I'd lean toward DD and for sealed, I'd lean toward JL. Since enclosure has such a large impact on sound, I'd decide on what enclosure works best for you, then decide on the proper sub.
Thank you, I'm leaning in the ported sql direction. I've just been back and forth with these 2 sets I've jl before, however I've never been able to listen the dd audio set.
First set are a DD audio 1112 (https://ddaudio.com/1100-series/hi-def-tuned/1112/)series 4 ohm.
Second set are the Jl audio 12 w3v3 4 ohm
https://www.crutchfield.com/p_13612W3V34/JL-Audio-12W3v3-4.html. just need a bit of input on which I should get. Amp I'll be using is the Rockford Fosgate R2-1200X1.
Box will be determined by the sub I get.
Thank you all for input.
Ever hear of ATOMIC? I used to use those decades ago...the Apocolypse 12 was a wicked sub!! :)
Then I'd probably lean toward the DDs. There are a ton of options out there. Alpine Type S or R, Dayton has several good subs, it's an endless list.
sweetloki
CarAudio.com Newbie
sweetloki
United States
AnthonyO
