which box design should i go with?
billabongcr
Yep
I designed a box on RE's website using their new box design program. Came out:
Box Width: 35
Box Height: 19
Box Top Depth: 10
Box Bottom Depth: 10
Wood Thichness: .75
Square Port Height: 17.5
Square Port Width: 1.5
Square Port Lenght 1: 7.75
Square Port Length 2: 8
Total Port Length: 18.75
Square Port Diameter: 5.781222885
Square Port Area: 26.25
Square Port Volume Internal: 492.1875
Square Port Volume Displaced: 503.4375
Box Volume(Ft3): 2.592
Box Volume(In3): 4479.6875
Tuned Frequency(Fb): 34.4507186306804
Box Bottom Plate: 35 x 10
Box Top Plate: 35 x 10
Box Left Plate: 9.25 x 17.5
Box Right Plate: 8.5 x 17.5
Box Back Plate: 35 x 17.5
Box Front Plate: 32.75 x 17.5
Port 1: 7 x 17.5
Port 2: 8 x 17.5
Or someone here on CA designed a box for me..came out:
Number of drivers : 2
Box type : Vented
Box size : 2.500 ft^3
Tuning frequency : 37.00 Hz
Vent : 1 vent(s)
26.50 in length for each
2.50 x 17.50 in rectangle
which would be better to run my 2 SSD 10s? both subs will have about 1k on each woofer. which of these box designs seems more accurate for my drivers. ive never really did a box design before..and my calculations comes out closer to one than the other..i just want to see who agrees with the one i think i should go with
so..RE or CA member?
ok i did some more measuring..with my subs an inch apart and 2 inches from the end of the box..my port wall on the inside will be exactly to the outside perimeter of my sub..leaving the actual port wall about 2 more inches away from my motor on the inside. good?
if that makes sense
maybe this will help
sub mounting is 6'
port=1.5. that leaves 7.75''
so i have 1.75'' of clearence between port and sub
if i make the volume of airspace smaller..will that give me more room between port and sub?
or should port go in middle
billabongcr
Yep
billabongcr
Florida
billabongcr
