Which American Bass to go with this amp.
AL210
PA
Just picked up the AQ Q1-1200 amp. 870 RMS@2 ohm. Will be running on stock electrical so not looking to do 1 ohm.
Looking at the American Bass 10 inch TNT or XFL (for $10 more) to use with this amp. I'm afraid to run my little Alpine S on this amp. My other thought was to try this NVX-VC104. SQ first SPL second.
what car do you have, with the big 3 and a 90 amp alt you should be ok with 1200 as long as gains are right and other accessorys aren't pulling to much. buddy has a 120 amp alt and a 105 AH AGM batt and he running 800 on his subs and 300 on his speakers with only .2volts of drop
dont be scared go for 2 xfl d4 and run that amp to 1 ohm, then later on upgrade your amp to the aq 2200 and those 2 xfl will still be able to handle the 2k amp
dont be scared go for 2 xfl d2 and run that amp to 1 ohm, then later on upgrade your amp to the aq 2200 and those 2 xfl will still be able to handle the 2k amp
Fixed. The xfl will take the power of that amp alone. Just do the big 3 Should be fine then
Yeah I have a 150 stock alt on my lil ole Ford Focus. Running one AT Strato at 500 rms 2 ohms and my lights dim. I think it's because Im running 8 gauge wire to a 4 gauge amp lol ;/
get 4 gauge wire ,and a big 3 kit
yeah Im getting KnuConceptz 4 gauge OFC amp kit and the Audio Technix 4 gauge big 3 kit.
and Im looking at getting either 1 12" XFL in a 2.5cf ported box on 900 RMS, or 2 12 AB Tnt's/SQ 12" 2.5s in a 2.5cf sealed box on probably about 1.1k RMS
got about a month to make my final car audio decisions before I start doing performance mods. So many choices!
yeah Im getting KnuConceptz 4 gauge OFC amp kit and the Audio Technix 4 gauge big 3 kit.and Im looking at getting either 1 12" XFL in a 2.5cf ported box on 900 RMS, or 2 12 AB Tnt's/SQ 12" 2.5s in a 2.5cf sealed box on probably about 1.1k RMS
the xfl 12 in a 2.2 cubic ft box tuned at 33 hertz will be loud ,but will want much more than 800 rms 1500 rms would be deal
Yes, they are definitely beefy. I beat the snot out of this one to find it's limits and it took it rather well. For the abuse I put it through and...
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
Yeah I had torn one down and used my digital calipers to measure coil size ID & OD and winding height and spiders all had it written down and had...
AL210
AL210
PA
mylows10
    May 24, 2024
    May 23, 2024
