Which 12" sub for an infinite baffle application?
ScottGS400
I recently put a system in my GS400, I have a sealed 10" Infinity Perfect in my trunk but I'm not getting a lot of output from it, partially since it's being underpowered by the 5th channel on my Alpine MRV-F450. I removed the stock factory subwoofer from the rear deck and have seen pictures of another install in a GS where they bottom-mounted a 12" sub to the rear deck (firing through the factory opening) and ran it infinite baffle. I'd like to try running an efficient 12" sub in this configuration... I don't really want to pick up another amp so it'll only get about 200 watts from the Alpine.
Any recommendations on a good sub for this application/power level? I was thinking maybe an IDQ 12 but can't find a lot of information on running a 12 in infinite baffle.
thanks, Scott
search yahoo or google. That's what I did before I bought my ID Max 10's. Because I was thinking of running them free air too. Just enter infinite baffle in parenthesis, and seacrh.
I don't know what to tell you about your output problem. 200 watts isn't much of anything, especially in a trunk. It takes 200 watts just to run my 6-3/4 component set.
In case you didn't know their web address here it is http://www.imagedynamicsusa.com they'll have a number that you can get in touch with a technician to see about your infinite baffle setup. Good luck getting a hold of an Image Dynamics tech though, they have the worst customer support I've ever witnessed. It took me 15-20 dollars in long distance charges over a 3 week period just trying to get ahold of one of their technicians. But if your lucky enough to reach one, they have a wealth of information.
Good Luck //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Also, go to the bottom of this page under 'Similar Threads' and check out one of those threads. One of mine is there too. One of those might help you //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
ScottGS400
ScottGS400
Mountain View, CA
Str8Up
