thaar411
Sub will installed in a 2002 Pontiac Firehawk (***** Am) in a drivers side stealth box in the rear well. The box volume will roughly be .6-.7ft^3. The drivers I'm considering is the Fi Q10 the CDT QES-1020, and two Peerless XXLS. I listen to pretty much everything, however, hip-hop and rock are played a majority of the time, and am looking for an SQL setup. Price doesn't matter. Here are the specs for each:
CDT QES-1020: http://cdtgold.com/pdfs/QES-1020W.pdf
Free Air Resonance: 39.8 Hz
Voice Coil DC Resistance: 3.42 Ohms
Voice Coil Inductance @ 1 kHz: 4.7 mH
Mechanical Q (Qms): 6.63
Electrical Q (Qes): 0.403
Total Q (Qts): 0.38
Compliance Volume (Vas): 11.0 l; 0.39 ft3
Moving mass, Diaphragm: 247 Gr
Motor Force Factor: 22.89 Tm
Nom. Diameter: 10” (250mm)
Cone: Kevlar-Paper Honeycomb
Surround: NB Rubber
Sensitivity: 84.4 dB
Power Handling: 500 WRMS (1000W Pk)
Frequency Response: 10 ~ 400 Hz
Nominal Impedance: 4 Ohms
Voice Coil Diameter: 2.6” (66mm)
Xmax: 20mm
Magnet Weight: 140 Oz stacked
Fi Q: https://ssl.perfora.net/www.ficaraud...iew.shopscript
Q10
DUAL 1 | DUAL 2
Fs: 34.1 Hz | 34.0 Hz
Re: 0.70 Ohms/coil | 1.4 Ohms/coil
Qms: 7.31 | 7.38
Qes: .37 | .37
Qts: .36 | .36
Mms: 230g | 2235g
Cms: .88mm/N | .88mm/N
Sd: 310cm^2 | 310cm^2
Vas: 11.8 l | 11.8 l
Spl: 83.3dB 1W/1m | 83.2dB 1W/1m
Bl: 13.9 N/A | 19.6 N/A
Xmax: 28mm
Rms: 1000W
Sealed box: .2-.6 cuft HQTS
Ported box: .5-1.2 cuft @ 28-33Hz
Sub OD: 11.000”
Cut ID: 9.250”
Mounting depth: 6.500”
Displacement: 0.12cuft
Peerless 830876: Parts-Express.com:
Power handling: 175 watts RMS/350 watts max
VCdia: 2"
Le: 1.5 mH
Impedance: 4 ohms
Re: 1.7 ohms
Frequency response: 39-2,000 Hz
Fs: 39 Hz
SPL: 92 dB 2.83V/1m
Vas: 0.83 cu. ft.
Qms: 6.79
Qes: 0.47
Qts: 0.44
Xmax: 12.5 mm
Peerless 830842: http://www.madisound.com/catalog/product_info.php?products_id=1467
Znom 4 ohm
Re 2.6 ohm
Le 4.2 mH
fs 19.2 Hz
Qms 8.74
Qes 0.19
Qts 0.19
Mms 133.8 g
Cms 0.52 mm/N
Sd 352 cm2
BL 14.9 N/A
Vas 88.4 ltrs
Xmax 12.5 mm peak
Voice Coil Ø 51 mm
Sensitivity
2.83V / 1m 88.4 dB
Power (IEC) 350 W
Magnet weight 2.4 kg
Many thanks!
Total Q (Qts): 0.38
Surround: NB Rubber
Xmax: 20mm
Q10
DUAL 1 | DUAL 2
Qms: 7.31 | 7.38
Qes: .37 | .37
Qts: .36 | .36
Mms: 230g | 2235g
Xmax: 28mm
Rms: 1000W
Sub OD: 11.000”
Cut ID: 9.250”
VCdia: 2"
Le: 1.5 mH
Impedance: 4 ohms
Re: 1.7 ohms
Fs: 39 Hz
SPL: 92 dB 2.83V/1m
Vas: 0.83 cu. ft.
Qms: 6.79
Qes: 0.47
Qts: 0.44
Xmax: 12.5 mm
Znom 4 ohm
Re 2.6 ohm
Le 4.2 mH
fs 19.2 Hz
Qms 8.74
Qes 0.19
Qts 0.19
Mms 133.8 g
Cms 0.52 mm/N
Sd 352 cm2
BL 14.9 N/A
Vas 88.4 ltrs
Xmax 12.5 mm peak
Voice Coil Ø 51 mm
Sensitivity
2.83V / 1m 88.4 dB
Power (IEC) 350 W
Many thanks!
