whats causing this
  • 2
dan3286
nc
the volume on my stereo will just randomly turn down and i just wanted to make sure its nothin bad. its a 93 with a stock system. ill drive down the road and it will randomly turn itself down.... is it just a bad h/u or is it somethin that could really mess up the car
A lot of the newer cars and trucks have a feature that will increase the volume if the road noise increases (for example). It will also decrease the volume as you get off the Interstate or as it senses the road noise decreasing. This feature can usually be turned off or it's sensitivity adjusted. The cars I have seen it was a collar knob around the volume knob. I'd suggest getting out your car's manual and see what it has to say.
Hope that helps. God bless you.
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
I think your front stage is spot on. If your DSP has a dongle that connects to your phone, then you are getting the full clear signal. No need to...
22
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
3K
dan3286
dan3286
nc
Frraksurred
winkychevelle
    May 24, 2024
