whats better or are they worth it
jr whos junior iv been doing car audio for 10 years buddy and i have people pming me all the time and locally helping them with information and installations. i have more knowledge then u will ever have, and ill dont just throw some random bullshit out their when you know nothing you are talking about
I always know what I'm talking about. You prove time and time again that you don't and it's why most people think you're a spam bot until they hear you get butt hurt. You're just a loudmouth douchebag who thinks he knows but doesn't have a clue. You know more than me? I guess since you KNOW that, you're going to have to prove it.
Put up or shut up toughguy. Also, learn to edit your post. Don't post 4 or 5 times just because umad bruh. I like how you assumed i was talking about a certain brand. lol. Again, you proved my point how if someone lets you, you talk yourself into a hole. You're an idiot and everyone knows it. You should do yourself a favor and take a permanent hiatus from posting on this site.
Also, before you post again... if you want ANY credibility, post cadence and mmats 4 ohm efficiency rating and a link to it to PROVE that it's more than the sundown YOU chose to compare it with.
Then also, since you claim you've posted useful things in this topic (that was clearly a lie) post what those two amps' 1 ohm efficiency rating is, so we can accurately see how long the fuse would last on a sine wave. (After all, who is an amp manufacturer to tell the end user what duty cycle they can use their amp at to get rated output?)
Cadence A5+HC 600 Watt Competition Mono Block Amplifier - eBay (item 290368818833 end time Jul-08-10 10:47:34 PDT)
95 percent effecient buddy look ****ing moron you have no proof of anything you have stated non at all, what have you said but not those amps dont put out rated well prove it wrong,
secondly the cadence thing was posted at will
Frequency Response (-3db) 10 Hz to 275 Hz
Signal to Noise Ratio
Distortion @ Rated Output
Damping Factor @ 100 Hz > 125
Input Sensitivity 150mV to 2.5Vrms
Idle Current 1.2 amp
Efficiency @ full power >76 % full power meaning 1 ohm or 2 ohm or.5 depending on amp cause they make there stuff right here in america they offer all versions not just 1 ohm hence why the price tag.
matts numbers at
Mmats Pro Audio
this is an american made masterpiece ok not some korean board, thats why they are so small and effecient, they use 16v internall discharge parts and 120v rails.
also no one has called me a spam bot but you, i get pm's all the time about what to buy etc.
you have no proof behind what you are saying i posted results on mmats boards
I have clamped the MMats 3000.1d, and these were my results @ 3.9 ohm (Reactive Impedance), Nominal load was 1ohm, and clamped a total of 1492 watts...then I later clamped it again @ a (React. Impedance) of 1.3 ohms, with a nominal load of .5 and it clamped a nice 3148 watts.....so yes they are still as good as they used to be if not better.
I will be recieving this week the Maxx Link and will be linking 2 MMats 2000.1d and will let you know the results of the clamping...if your interested.
quoted right off tempro on 200 amp of fuses hmmmmm 3300 rms at 1.3 ohm and its rated at 2700x1 and mmats posts real time music vs sinewave ouput unlike most other companies who just post sinewave
Lol lots of hilarious assumptions there. Everyone knows you're an idiot. The 1000d is only 65% efficient at 1 ohm? Lol most a/b amps are close to that. Hell a jl slash series is that efficient. Again, you're just lying trying to prove your point yet again.
come on man prove me wrong ur so smart right hmmmmmmmm, your wrong you moron
http://www.edesignaudio.com/product_info.php?t=2&products_id=550
shows fuses are 120 righ but max current draw is 280 amps how is that
im just posting links your just talking out your ***, because if its not a forum boner its not any good, mmats would wipe the floor with many amps big on here its just they cost a lot.
Cadence A5+HC 600 Watt Competition Mono Block Amplifier - eBay (item 290368818833 end time Jul-08-10 10:47:34 PDT)95 percent effecient buddy look ****ing moron you have no proof of anything you have stated non at all, what have you said but not those amps dont put out rated well prove it wrong,
matts numbers at
Mmats Pro Audio
OH MAN!!! you just proved yourself horribly wrong. Nothing needs to be posted. There is no amp 95% efficient. Since the item description had typos anyways, it's obviously not credible:
Rated RMS Power: 25 Watts
300 Watts RMS Power @ 4 Ohm Mono
600 Watts RMS Power @ 2 Ohm Mono
Frequency Response: 10Hz – 500Hz
Input Sensitivity Range: 200mV – 8 V
Input Impedance: 22K ohms
Total Harmonic Distortion:
Signal to Noise Ratio: 60dB
Damping Factor @ 100Hz: >200
Narrow “Q” Parametric Bass Equalizer: +/- 18dB @ 45Hz
Variable Low Pass Crossover: 24dB per Octave 50Hz – 250Hz
Subsonic Variable High Pass Crossover: 18dB per Octave 20Hz – 50Hz
Output Impedance: 2 – 8 ohms
60 Amp Fuse Maximum
Digital Amplifier Efficiency: >95%
Dimensions (L x W x H): 10” x 10” x 2.65”
25 watts rms? You fail you idiot.
Also, I asked for a link to the cadence thing. You could not provide it so you fail. The mmats may actually be 76% efficient at full power. We all know that class d amps get more efficient as they are turned up. It's the nature of the beast. The burden of proof is on you... not me. I already know the answers and you're the one making the claims and trying to prove something that is not provable. You did not find the efficiency of the sundown or the cadence at 1 ohm. You've got to compare apples to apples. You've actually not compared anything so far. You have posted a lie about the cadence amp. You posted something from mmats, but you haven't posted anything about the sundown. Let's see an actual comparison showing some clamped results.
You've blatantly lied now. Anyone that reads this will know it and see that you're an idiot who grasps at straws to preserve his ego. I'm going to guess if you keep lying about this, you're going to get jake's attention and he'll prove you wrong himself. You should quit while you're ahead.
mclerico does get a bit pushy at times, but the guy definitely has good intentions. He links to the same equipment quite a bit, but most of the guys who actually offer advice are guilty of the same thing.
Anyway, the guy does know what he's talking about most of the time. It's just that a lot of his decent advice is buried within posts that contain a hell of a lot of links to equipment. This causes a lot of people to overlook some of the things he has to say.
OH MAN!!! you just proved yourself horribly wrong. Nothing needs to be posted. There is no amp 95% efficient. Since the item description had typos anyways, it's obviously not credible:Rated RMS Power: 25 Watts
60 Amp Fuse Maximum
no typo that link is directly from cadence i will email jacob and see what he has
but let me show you another amplifier i was completely guesstimating as i said
Operating Voltage:
14.4 Volts (11-16 Volts allowable)
Power Output:
Max Power 1000 Watts (not verified)
Rated Power 200 watts into 4 ohms, 400 watts into 2 ohms & 500 watts into 1 ohm
Measured Power 269 watts into 4 ohms, 414 watts into 2 ohms & 517 into 1 ohm
Current Draw @ Max Power:
21.7 amps @ 4 ohms, 36.4 amps @ 2 ohms, 55.4 amps @ 1 ohm
Amplifier Efficiency @ Max Power:
89% @ 4 ohms, 81% @ 2 ohms & 66% @ 1 ohm
http://www.audiogearreviews.com/reviews/amplifiers/review-kenwood_kac8151d.asp
most class d amps fall between 60 to 75 percent at 1 ohm and its usually a big drop
Price & Contact: $1989.19 (MSRP); 800-444-5671; Lanzar Car Audio
Rated Power @ 14.4 VDC, 1%THD: 2000 Watts x 1 into 4 ohms; 3000 Watts x 1 into 2 ohms; 4000 watts x 1 into 1 ohms
Measured Power @ 14.4 volts, less than 1% THD: 2034 Watts x 1 into 4 ohms; 3026 Watts x 1 into 2 ohms; 3516(current limited) watts x 1 into 1 ohms
Current Draw @ Max Power (14.4 volts): 183A @ 4 ohms; 309A @ 2 ohms; 432A @ 1 ohm
Efficiency @ Max Power (14.4 volts): 77% @ 4 Ohms; 68% @ 2 ohms; 57% @ 1 ohm
http://www.audiogearreviews.com/reviews/amplifiers/review-Lanzar_OPTI_4000D.asp
sundown dosent post their 1 ohm effeciency
and yes cadence makes cheater amps so its rated at 25 watts at 4 ohm buddy, so you can put 20 of them in your trunk and still be in the 0-600 class.
60 Amp Fuse Maximum
http://www.zedaudiocorp.com/Technical/Amplifier-Efficiency.pdf
read and the a5 and a7 are from the same line same amp just one runs at 2 ohm and the a7 runs at 1 ohm same ratings at 4 ohm
My A7 is putting 1406 watts into a 1 ohm load with 13.0 volts of power.
12 volt testing yielded 1136 watts into 1 ohm
Oh yeah, its a bad little amp.
Loyd L.
my a7hc does 1428 at 1 ohm mono @ 14.4 volts
this was off an impedence weight and a steady 14.4 volts.
quote:Originally posted by alaska:
ok...i must be doing something wrong
i have my 2 subs wired for a 2.2 nominal load (according to the voltmeter with system off) so that should be about 800W according to cadence.
using a clamp on ammeter and my multimeter and 42Hz (i am tuned to 30Hz) i measured 53.1V AC out and a current of near 8A.
using P=V*I i get only 425W...hmmm
using the other two versions (V^2*R and I^2/R) i get completely whack values (4000W and .04) but i remember my circuits instructor telling us that of the above two there is one that can only be used under certain conditions. but i don't remember what it was
hmmm...i'll retest...hmmm, maybe i'll even rewire for a lower impedance, or just hook up one and test it with my competition ports cuz i need to do that anyway.
if anyone knows what i did wrong tell me plz!
53.1²/2.2 = 1281.64w PEAK * .707 = 906.12 watts RMS
-john jjh@fyi.net of Sound Impressions
"Boomin' Taurus"
Its all about Brand Loyalty...
...supporting the manufacturers that support their dealers...
900rms at 2.2 ohms pretty good hmmmm
cadence a7hc = 1428 watts?
why dont you just listen, as i said i dont care what sundowns 1 ohm load is i just posted 2 other amps the opti 4000d which is a well respected korean amp on these forums. class d and it does how much at 1 ohm
as i stated before most class d amps do between 60 to 75 percent at 1 ohm, when you say a/b do 50 to 60 percent thats at 4 ohm, thats why most a/b amps dont go below 2 ohm because of the huge drop between 2 ohm and 1 ohm, thats why when people run there amps at .5 ohm the amount of power needed goes way up because the effeciency goes waaaaaay down.
and like i said it was no way saying sundown is a bad company etc, i love their products and jacob might be one of the best guys in the industry to deal with, thats why really they move ahead of other companies is customer service,
Sundown Audio - SAZ-1000D
but his amp has 75 amps of fuses so using your method at 1000 percent 4 ohm effeciency it is 14x75= 1050 and at 84 percent effeciency which its not running at 1 ohm more like 60 to 70 its still only produces then 860 watts, hmmmmmm it dosent work when we all now the amp has been known to do more then 1000 watts plus
Sundown SAE-1000D
lol
MO.. one 1500d should be limited to 1 ohm nominal use in factory electrical systems.. for the sake of the car.. not the amp
now... to have fun with some juice..
1 amp, single 1000ca everstart maxx, 1 Eagle Picher 12a5000, factory alt
4 ohm nominal = 520 watts @ 88% efficiency (voltage fell from 14.3v, to 14.1v)
2 ohm nominal = 960 watts @ 84% efficiency (voltage fell from 14.3v, to 13.7v)
1 ohm nominal = 1635 watts @ 75% efficiency (voltage fell from 14.3v, to 12.8v)
.5 ohm nominal = 1890 watts @ 71% efficiency (voltage fell from 14.3v, to 12.8v)
.35 ohm nominal = 2245 watts @ 65% efficiency (voltage fell from 14.3v, to 12.8v)
amplifier did fine @ .35 with tones and music with the added battery
saz1500d deficiency and nominal, this is not before rise so i am assuming most likely, when .5 ohms nomial after rise it was at 1 ohm 1 ohm was prob at 1.5 etc.
and the saz15000d starts off at 4 ohm at 88 percent when the saz1000 starts off at 84 percent so hmmmmmmm
The 3 x 25 amp fusing posted on the Sundown website under SAZ-1000d is a type o, it has 3 x 30 amp fuses just like the rest of the Zenon based 1k's for the second time , for what it's worth , personally I could give a sh!t either way , but carry on.
You proved yourself wrong. Had you read it, you'd see that they said 95% efficiencies were attainable with class d but realistically 80-90% is practical. Why you may ask? The narrower the pass band the amplifier reproduces the more efficient it becomes. That's not good for reproducing music. That's why they included the "typical" percentages because usually class d amps fall in that range when it is capable of reproducing between 1-250hz. You proved yourself wrong, but of course you do not know that. LITERALLY NOWHERE did you show that any amp was 95% efficient.
the a5hc is 95 percent effecient at 4 ohm fact i posted the page buddy
just admit you are wrong and move on
and as you know zed did design the a5 and a7
Where did you post that? You posted so many times I don't see it. If you ever do indeed prove anything I will admit it. Until then, you're still a liar grasping at straws.
This kind of shit doesn't help anybody least of all OP.
joeybaldamore
joeybaldamore
Fargo,ND
mclerico83
