whats better or are they worth it
My formula? Show where I used a formula and it was wrong you idiot. Do you remember when I said that fuses can take more power than they are rated for? They just can't take the 30% more like you were claiming indefinitely. You're STILL wrong you're just too stupid to know it.
you said its impossible for an 80 amp fused amp to make 1200rms your formula you used was wrong so shut the hell up and move on
Look I know fuses will do double their rated current for a long time before they blow so technically it's possible for a split second on music but, 1400w / 80 amps = 17.5v @ 100% efficiency. This seems like quite a stretch once you factor in the actual voltage they will see and efficiency. 1000w is pretty reasonable. 1400? not so much.
dont question with your bs then i tell you and you tell me im wrong
joeybaldamore
joeybaldamore
Fargo,ND
mclerico83
