keefy248
BID BIG
i have 5-6 cubes n 2k what should i run in a car setup was going run 18 but need 6cubes plus
what is the plan?..just a sub or subs in the trunk? subs sealed from the trunk firing into the cabin?...what are the dimensions and design goals? SPL?..SQ?..SQL? Building the box in the trunk or not?i have 5-6 cubes n 2k what should i run in a car setup was going run 18 but need 6cubes plus
loud but clean,rap pop r&b music,electrical yes?im just looking for something loud,low n clean even look at treo ssx rd sonanceThere are so many choices that if you want some help you gotta narrow it down. Are you looking for sound quality or maximum loudness? what kind of music do you listen too? Is your electrical able to handle 2000 watts?If you have that kinda money to spend I wouldn't even consider a type r.
sub or subs.yes i dont like all the the rattling sounds horrible,sql loud low n clean,yes trunkwhat is the plan?..just a sub or subs in the trunk? subs sealed from the trunk firing into the cabin?...what are the dimensions and design goals? SPL?..SQ?..SQL? Building the box in the trunk or not?
what car is it, exactly?sub or subs.yes i dont like all the the rattling sounds horrible,sql loud low n clean,yes trunk
