What sub? JBL or Infinity
nerras
Which is the best?
1. JBL GT 120, GTO series, 250 W RMS/ 1000W, for 100$
2. Infinity Reference 1230w, 300 W RMS/ 1200W, for 116$
3. Infinity Kappa 120.3se, 300 W RMS/ 1200W, for 130$
4. JBL Power P1200, 280 W RMS, for 120$
Which gives more powerfull bass (SPL). I will put it in vented box.
Thanks
The JBL power series will most likely give higher SPL numbers in a vented enclosure. However, for SQ, I would get Infinity References... you can usually find them at a good deal like 2 for 100 bucks or something.
sounddomain.com has 2 infinity reference 12" for $150 shipped!!!! I'm like you can't decide if i should get that or not. my other choice would have been 1 RE SE 10". good luck on the quest
But how sounds this JBL P1200, I have no ideas? I know about JBL P1220 - new model of power series.
The P1220 is a very good sub. 400wrms (under rated) with a peak of 1600w.
Where can I see a P1200 at? $120 is quite a bit cheaper then the what the P1220 cost.
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
193
535
nerras
nerras
Lithuania
meanman101
