tuskilla
What is better???
Which one can deliver lower cleaner bass??
Which one can deliver a bigger bass spectrum?
RE AUDIO SEX12D2
* Dual 2 ohm Voice Coils
* 1200 watts peak output
* 12" competition grade subwoofer
* 600 watts pure RMS
* Engineered with new magnet covers that aid in cooling the voice coils while protecting the magnet
* Flat wound voice coils
* Qes: .49
* Qms: 4.5
* Qts: .44
* Free Air Resonance -Fs: 25.1 Hz
* Vas: 72.9 liters
* Overall Diameter - 12.5"
* Bolt Hole Circle - 11.75"
* Motor Width - 6.25"
* Motor Depth - 3.25"
* Basket Depth - 3.25"
* Displacement - .15 cu. ft.
* Weight - 22 lbs.
* One-Way, Linear Excursion -Xmax: 18 mm
* Efficiency - 86.1 dB SPL @ 1w/m
* DC Resistance -Re: 2.8 ohm
* Mounting Depth - 6.5"
* Mounting Hole Diameter - 11"
* Dual Composite 2-piece Cone
* Rubatek Foam Surround
* Cast Aluminum Basket
* Tork-Tite Terminal
* 3" 4-layer Aluminum Voice Coil
* FEA Optimized Motor Structure
* Triple Stack Maganets
* Progressive Spiders
* Wrap around Rubber Gasket
Rockford Fosgate Power T112D2
# Subwoofer Size: 12"
# Subwoofer Design: Round / Circle
# Shallow Mount Installation: No
# Voice Coil(s): Dual (2 voice coils)
# Impedance (per voice coil): 2 ohms
# Peak Power Handling: 1200 watts
# RMS Power Handling: 600 watts
# Woofer Surround: Rubber
# Woofer Composition: Aluminum
# Sealed Box Volume: 1.0 - 1.5 cubic feet
# Ported Box Volume: 1.25 - 2.25 cubic feet
# Sensitivity: 86 dB
# Frequency Response: 20 - 200 Hz
# Xmax (millimeters): N/A
# Top Mount Depth: 6-3/4"
# Cutout Diameter: 11"
# Recommended Enclosure Type: Ported / Vented, Sealed
RE AUDIO SEX12D2
* Qes: .49
* Qms: 4.5
* Qts: .44
* Vas: 72.9 liters
* Weight - 22 lbs.
