What size speaker wire do i need to run from amp to sub. 1000 rms
  • 6
I run 8g and make all my own connections //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Excellent !!//content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
What size do the push terminals on the subs themselves usually except max?
Generally 12 ga some up to 10 ga. But with a proper connection, you can do just about any gauge you desire(Modifications never hurt for upgrading /customizing) You can solder any gauge you desire
Use the biggest your sub and amp can both accept.
I use 4 gauge sky high ofc between my Banda and Z's direct leads //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Had the 4 gauge laying around, and it fit in the amp's output without trimming the wire
[quote name='HomeGrown']4Gfit in your amp ?[/QUOTE]
Yep, it was a Banda Viking 5000. Power inputs were single zero gauge, unlike Taramps that are 4/0. However, they have 4 gauge speaker output terminals. I'm not sure if they're current monsters or what. I thought Brazillians were more voltage
My new 7000 is supposed to get here tomorrow. I could post pics if it does. @Boomsday; could probably verify it too. He runs Banda
would be nice if all amps had 4g speaker terminals and subs with min 4g standard . LOL I have to make the 4 g terminals if I want to put them on my Ampere but for me the 8g is plenty for 3800.1
[quote name='adulbrich']Yep, it was a Banda Viking 5000. Power inputs were single zero gauge, unlike Taramps that are 4/0. However, they have 4 gauge speaker output terminals. I'm not sure if they're current monsters or what. I thought Brazillians were more voltage
My new 7000 is supposed to get here tomorrow. I could post pics if it does. @Boomsday; could probably verify it too. He runs Banda[/QUOTE]
I was wondering if you made terminals for Banda's. If I had gotten a Taramps HD 8000, I would have gotten your dual 8 gauge outs.
I don't need any now though
Here is a chart that gives you relative cone size. Diameter of speaker*|*Cone area of speaker in square inches 18"*--->*254 15"*--->*192...
15
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
Tesla beat Edison. Why do you think we transmit high voltage ac? Cars are low voltage dc, which is absolute worst as far as efficiency goes, but...
61
The Camry
Hey, I Try.
The Camry
Western Oregon
Boomin_tahoe
    May 31, 2024
    May 24, 2024
