What should I upgrade my subs to?
NyQuil581/
I have 2 12 inch American Bass xfl subs. They are connected to a hifonics Brutus amp. I have an auxiliary battery as well. I can only turn my bass knob half way and then the speakers start to overheat and you can smell an odor start to come out. I’ve had them checked and I’ve had the amp turned down. I want something that will take the power from the amp and have a good deep bass. I’m in a car club so I want it to hit hard and crisp. I wanna stay with 12’s so I can keep my trunk space. I don’t know much about subs. The pair I had before these were Jl audio w3s. Any and all feedback will be appreciated.
Well then it depends on how much money you want to spend
Because you want a 1ohm final load you are going to need either dual 4 ohm or dual 1ohm subs
https://soundqubed.com/product/hds3-2-series-1200w-subwoofer/
$169.00 each
https://www.down4soundshop.com/Apocalypse-DB-SA252-D1/
$209.90 each
https://www.droppinhzcaraudio.com/c...ts/resilient-sounds-gold12-12-1000w-subwoofer
$289.00 Each
https://www.woofersetc.com/c-23-sub...w-rms-dual-4-ohm-sa-v-2-series-subwoofer.html
$369.00 each
In any case your going to need a new box and I strongly suggest ported
1) Every sub has different parameters and need different amounts of air space/ port space etc.
2) Your american bass subs should not be crapping out on you, it might have something to do with the box there in.
Better the box then it be something wrong with the amp
$169.00 each
$209.90 each
$289.00 Each
$369.00 each
1100 at the most it what I would hope to stay under. I was looking at sundown, jl audio, and skar so far. Out of the ones you have suggested which would give the deeper harder bass. And what do you look for to be able to tell? I don’t know much about what the rms and ohms mean. No one has ever explained that too me
No way you are over powering the XFLs on that amp. The smell and heat is from clipping. Swapping to subwoofers with a higher power rating would gain nothing but a lighter wallet.
How do I fix it? The box is ported, I don’t turn my bass knob up past half, I don’t have my bass on my EQ turned up at all. I have a fan in the trunk.
Headunit and amp settings should be set with either an oscilloscope or DD1 to make sure you have clean input into the amp and clean output to the subwoofer. I would also double check your wiring to make sure you are wired to 1 ohm with a multi meter.
Those XFL's can handle that amp easily. It sounds like you are using your gain button as a volume button. Do you have a clipping light in a bass knob in your dash?
If anything, upgrade your amp. Those XFL’s are nice woofers that can take abuse (obviously) and get loud. My assumption is the gain is set super high and you’re clipping the piss out of the amp. Box could be a factor as well. Posting pics will be great and you’ll get the help you need for sure.
first, set your amp gain right. heres how. the test tones are at the very bottom
The CT's are nice, That Sundown is a a frik'n beast!
885
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
737
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
849
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
NyQuil581/
NyQuil581/
Chicago
Kickstand
