What should I do?
venom107
The Graveyard Shift
Well right now my boxes arent carpeted and the inside of my trunk has no carpet at all on the inside it looks pretty bad, anyways I was wondering on how I could make it look better and how to do it. How do I go about carpeting my box? would you put down sound-deadoning material and carpet over it? How can you flush mount amps? I really want the trunk to look like a show car so any suggestions would help. Is there a way I could keep my spare tire in my trunk? There is a hard cardboard piece over my spare tire right in the middle of my trunk, any suggestions on how I could build a piece over it and still have access to my tire? Thanks, and if it helps I have a 93 Toyota Tercel.
use 1/2in. mdf board and build over everythinig, use your imagination (i cant cause i dont have ur car). Just cut a whole and max like a little box for your amp and screw it down, then have the wires run under the mdf board. u got a pic of your trunk? might be able to help ya out more.
3/4 would be fine, make sure you DO use 3/4 for a box, but for fabrication and just holding amps 1/2 will be easier to work with IMO. but im guessing u got some 3/4 layin around or seomthing in that case it will work just as good.
venom107
The Graveyard Shift
venom107
Independence, Kansas
mgaidica
