What should I do? Help.
Sir Plus
Sorry if this is in the wrong place, wasn't sure the best place for it. I bridged my Memphis MCA3004 on my HSK 165s. Power went from 75 RMS to 220 RMS. Now there is a point where the highs seem to run together and feel "hollow". When I first put the HSKs in and was running them on 75 RMS, I had the same problem. However, after many long hours adjusting the EQ on my HU (Eclipse 6610) I was able to fix it. Now with the extra power I just can't seem to get it dialed in. Should I use the Amp in 4 channel and bi-amp the comps and try to find the perfect crossover points using the amp and HU, or should I try going with an outboard EQ with more control and try to dial it in? Sorry for the long post. Thanks for the help.
Sir Plus
Sir Plus
Lubbock,Tx
Sir Plus
