What should I do (battery advising) hhelp
Chris.Bloemker
if i replace my ford battery with this HC600 Kinetik HC600 - Batteries and Battery Isolators - Sonic Electronix
Or should I just add it and run it in parrallel or series, i dont want to get into isolators and switches unless its the only way.
I have a ford taurus 2005
will I be able to run 2 alpine Type S subwoofers, with an alpine MRP-M500 and a crunch 4 channel amp running 4 5"x7" inch speakers.
BTW I have 0 gauge CCA wire with a tsunami fuse holder with volt meter.
and 0 guage ground
I have stock alternator
just run that battery up front and you will be fine you don't have a need to add a second battery it would just be a larger strain on your alt. and your voltage would actually go down a hair from not being able to sustain 14.4 on two battery's being it's factory
Chris.Bloemker
Chris.Bloemker
Orlando, Fl
audiolife
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
