What rms rated and peak power rated 6X9's can I use on my MTX Blue Thunder Pro 400x5
A real three way does have low mid high. The speakers you are thinking of have a almost full range 6*9 plus several crappy tweeters. If you start with crap, adding more crap to it just makes a bigger pile of crap.
by any different u mean the size?
Basically, although it is not the size it is that they are all tweeters, they are covering the same frequency. This causes issues with the response. It doesn't help anything, it makes everything worse.
so i should go with 2way speakers then huh....and 1 more question im confused about on the mtx specs it says
25 watts x 2 into a 4 ohm
50 watts x 2 into a 2 ohm
how do you read that wouldnt it have to read
25 watts x 4 or
50 watts x 4
since 4 is the number of channels not 2 channel?
25 watts x 4 or
50 watts x 4
correct. If it is a 4 channel.
I don't know what speaker you are looking at but these are good, and a great price:
Aura 6900RPM 6" x 9" 2-way Coaxial Speaker Pair 269-185
[/img]
i also found the same with this but i kinda get this since its just 2 channel
Rockford Fosgate Punch 400S 100W x 2 Car Amplifier at Crutchfield.com
100 watts RMS x 2 at 4 ohms
200 watts RMS x 2 at 2 ohms
400 watts RMS x 1 at 4 ohms in bridged mode
it means its 100 watts each channel when both are in use at 4ohm and 200 watts each channel when both are in use and 400 bridge but how do i read the rms on meach channel on mine when all four channels are in used or 3 or 2?
MTX decided to word it so it's F and R separately, even though they have the same power ratings. It's 25x2 @ 4 in the front and 25x2 @ 4 in the rear.
ok i get it now...1 more question how do i build a surface to place 4 6x9s on my back should i just lay the surface and mount the 6x9s or should i make like a type of box to house the 6x9s whould it make a difference in sound?
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
No issues there. The amp will output depending on the speaker's impedance rating. Are you using a component x-over or is only the tweeter with x-over?
995
Deff a beautiful constructed sub. The best thing about as well, they do perform very well too and have excellent C.Service and even Tech service...
21
4K
89Eldorado
89Eldorado
Houston
89Eldorado
