What noise is this from my subs
I normally use a test tone test subs. You don't need much power to get them moving with a 20 Hz sine wave.
Are those the tc sounds subs that can be taken apart? You could try pulling the motor to look for any issues.
They come shipped seperately. The top piece (cone, voice coil, and basket) is shipped in a box and the bottom assembly (Magnet) is shipped in another box.
your basket doesn't look like it's tightened down all the way either, looks like there is a gap between the basket and top plate.
Thats correct. That is the reason why his subs arent performing properly. Since its not tightened down all the way, there are several mechanical issues that are causing his issue. They need to be tightened down all the way in order for the subwoofer to function properly.
TJ, if you ran this sub like this for very long, you very well may have damaged the subs. I took the subs out of the box and assembled the top and bottom and i fit flush. It was purchased brand new from TC Sounds a couple months ago and had been sitting on my kitchen counter during that time while I was trying to sell them. I never got to test the subs.
I traded in two of my TC1000's that were blown and Thilo offered me a deal to trade. I sent in two of my TC1000 12's and was given an LMS-R 12. I wanted a pair so I purchased another LMS-R so I could sell these as a pair, knowing I had no way of running these subs in my crew cab Sierra. I have been planning for the past 6 months to run 4 Sundown SA-8's, which I just ordered from my dealer and I get to go pick the 4 SA-8 V2's up at his store next week.
I purchased the LMS-R 12's to sell, not so I could run them. I dont have the room in my truck and it was never my plan to run 12's. I have been running 12's for the past 10 years. I wanted to do something different. So the money left over was going to my SA-8's. But since the OP wanted them by Friday, I opted to upgrade his shipping, insure them, ship two subwoofers in 4 boxes, just like they came from TC Sounds, insured them, Indirect Signature Required and ended up paying $99.98 for shipping so I actually didnt make any money on them after shipping.
So TJ, you need to tighten the bolts down all the way and make sure there is no gap, reinstall the subs and hope that you didnt damage the subs by rwn and with running power to the subs with the gaps in like that. You can see pictures from my For Sale thread that I had both subs with the top and bottoms attached, bolted down and no gap in between the top and bottom assemblies.
If there is an issue with the subs, then they were damaged either by running power with the gaps and not being bolted down all the way and/or the one thing that I said was EXTREMELY important when I told you when you were marrying the two assemblies and sliding the voice coil down into position. Its very important when doing this, that you do not let the voice coils touch the sides when lowering it down to the motor. If you do this, you can damage the voice coils.
Another thing while you have the subs out, is to use a DIMM on each voice coil. If the readings are off, then you damaged the voice coils unfortunately and would have to buy a new top assembly, which Parts Express sells them seperately, which is actually good for you so you wouldnt have to send them off to get them fixed.
Let me know how it goes after you bolt them down. I can work with Thilo and/or Kyle with you, but like I said, if its still not working, its due to either or both of those reasons I stated above as they are brand new subwoofers that never saw any power or been inside of a subwoofer box. I even have pictures in my For Sale thread showing DIMM readings I believe. I could be wrong. Since they are brand new, then I may not have taken the time to use my DIMM.
Kinda looks like the screws arent straight to me but not sure
When I installed the top and bottom assemblies, it took me a bit to get them to align right, but after about 5 minutes on each sub, I was able to get them to bolt down with them being straight.
TJ, if they arent straight, dont force them. Make sure they are aligned perfectly straight. I got all 4 bolts on both subs to align perfectly. it takes time and a little patience, but they align up. What I had to do was tighten the bolts down like you do when you put on a tire. Do one bolt with a full turn, then go directly across and do a full turn there, then do the side one with a full turn and so on till you have it bolted down completely. I believe I told you thats how you had to do it in a text message when you were having issues getting them to align.
they havent been ran for longer then 30 seconds they arent hooked up now but i wont be able to test it for atleast a week.....may try this weekend off just my battery but they were hardly ran
---------- Post added at 03:18 AM ---------- Previous post was at 03:17 AM ----------
i will take them apart and re tighten them and get back to this thread
Where is corey when u need him??? Bet he can tell what it is in under 2 sec's. Not sure who is at fault but I could see this turning south quick with seller saying all is brand new and buyer having a clunk clank right from the box....
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
Yes i know that's what i was planning on. Unfortunately the rvca's are a little difficult to gain access to. My other thought was to wrap a wire...
Imtjnotu
Me Gusta Edition
Imtjnotu
San Diego CA
ciaonzo
    May 12, 2024
Brendon Jenness
    May 11, 2024
