What material do I make ports out of?
  • 4
klein
6
CA
This is my first post here after about a couple of weeks of lurking the boards. I have learned a wealth of information from all you guys/girls so thanks a lot.
Anyways, I've started making an ported enclosure for 2 JL 12W0's and I am wondering what I should use to make the actual ports themselves. JL's recommended measurements call for one 4" diameter x 12" length cylinder for each sub. I was considering PVC piping that they sell at home depot in about 10-foot lengths that I can cut down to spec. I'm thinking this is the wrong way to go for some reason.
So how would I go about porting the enclosure? And what method would I use to suspend the cylinder. Thanks in advance- your guys help is much appreciated.
I prefer square (slot) vents. They're easier to manage (you can adjust the port area as needed) and they're not that difficult to make.
does sound differ from different port types? tubular like pvc or slotted?
Not until you start getting into large drivers that move a large amount of air. In that case i would go with a slot or square port. For something on the smaller side round ports work fine.
I have use PVC before and it works. All I did was glue and tube in place in the hole and added a few small, flat head screws in the inside of the port and screwed it into the MDF.
I am sure there are hard woods that are much denser than MDF. Don’t know if they would be better for a build, but they would certainly be...
24
3K
The late 80's early 90's car's OEM speakers were of the same quality as today's offerings. The main difference was the rear speakers were enclosed...
10
You're not trying to figure out the mass of air in your 3" port or whatever, you're trying to figure out the mass of air that you would need in an...
12
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
The black rca out is your mono sub output. That is the one you would use for signal to your sub amp.
klein
klein
CA
Trixter
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
