What i've been up too... Dual Folded horn done by Toxic Bass for Fattony911
What was that 4? I was asking a simple question and i actually found your posts informative but why be an *** about it?
they MAY work in a pickup, with a cutout... or the whole rear window remove, and the horns mouth there //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
lol, I metered one of my 12inch horns at home, off about 500watts, with the sensor sitting level with the mouth of the horn, it did numbers as follows:
no, wait, cant find the number... banned from the forum I posted them on... oh well... ahah
lol.......that sux.......i eventually want to do a blowthrough in a bandpass enclosure with 4 mag 12's but i wouldnt know what order would be optimal for them
ok, I found the numbers, but they werent as good as I thought... ah well...
138.5 at 70Hz
138.0 at 60Hz
136.0 at 50Hz
134.2 at 40Hz
130.1 at 30Hz
126.1 at 20Hz
it was metered with the TL sensor like 2 feet from the horns opening...
what were the max dimensions of the enclosure?
I'm sure you could come up with something that actually suits the woofers...
anyone?
what vehicle was this enclosure going in? //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
In this case, it really doesn’t take
long for some folks to be revealed as clueless. And the first tip-off
presents itself in form of a comparison of my design to a front-loading
exponential horn and then a high-tune transmission line. Apples and
oranges have more in common. Their attempt at applying quarter-wave math
to a conical rear horn, alone, aught to give you an idea of how skewed
their references are. Granted, a front loading horn (whether conical or
exponential) does achieve it’s coupling / loading effect through a
wave length multiplier along with gradual velocity-to-air mass transfer
along a designated contour. Rear horns, on the other hand use the air
mass inside the horn as a resonant “spring mass” much like a
ported enclosure allowing the horn to be shorter yet still effectively
couple the back-wave to the air mass at the mouth of the port. Take a
semi-conical folded rear horn like the “snail shell”, for
instance; in most of them, the effective horn length averages roughly 65
inches so, according to that forum’s take on horns, most snail
shells are in fact designed to reproduce mid-bass. At any rate, I do hope
you enjoy the sound quality, response, and the output of your design.
Pete
Sales, Team Toxic Bass
In this case, it really doesn’t takelong for some folks to be revealed as clueless. And the first tip-off
Pete
sounds like pete calling a bunch of people ignant by proxy LOL
iamamp3pimp
Bass Heads Entertainment
iamamp3pimp
Tampa FL
atlninja82
