My thoughts exactly. And all in ported boxes as well, regardless of what the sub actually wants...
Might have ended the way it did because you were looking for something specific, but your results are far from scientific or conclusive. Quite questionable in fact.
From a measured accuracy standpoint, the W7 is the best of those listed. That a lot of people don't like the way it sounds is a fault with their hearing and what they like, not the accuracy of the driver.
I tested sealed boxes for each sub as well as I stated in the beginning.
Seeing as how accuracy was the only criteria I used to measure with ears only this test could have been by nature a little subjective.
But this test was for me, not to publish, and ultimately your ear is the final judge of how a sub sounds Correct?
These were "real world" tests.
And what constitutes the JL W7 being the best in accuracy from a measured standpoint? What is the technique to measure accuracy?
To anyone that has ever used many different drivers, you will know that one can look better than another on paper, but in the real world, paper doesnt mean anything.
Here are my results from the JL W7 testing.
Chevy HHR
Ported Box
--SPL with 500w = 133.3 dB
--SPL with 1000w = 135.7 dB
--Frequency response from 20-60hz
I scored this on a 40 point system similar to IASCA rules. Difference is that I counted every frequency from 20-59 hz and not the full bandwith at 1/3 octave.
Starting with 40 points I found my base SPL for each sub and deducted a point for every frequency that was 2 dB off as opposed to 3dB in the full bandwith test. Every 2dB deviation is 1 point.
JL W7 scored 8 points.
--Accuracy
I measured on my own scale of 1-10
JL W7 measured a 7
--Durability
10min. 1000w 50 hz tone = Sub started smoking after 8 minutes, did not blow.
10 min. 2000w 50 hz tone = 1 Coil failed in just under 2 minutes.
Sealed box testing
--SPL with 500w = 129.1dB
--SPL with 1000w = 132.9 dB
from same test as above
JLW7 scored 20
--Accuracy
JL W7 scored 8
Agree or dont agree, if you have a thing for JL you wont pay attention to any result that shows other subs beating them anyway.
These tests were for me and I found my perfect sub.
