What is a good rear fill for this front stage???
thetruthc32
17
NY
I am getting the Cdt -CL-62 or HD42 Gold/regular which i will be connecting the kicker zx850.4 amp to. I wanted to know what would be a good rear fill to compliment this front stage that will support this much power as well, thanks
If your not running 5.1 ...I'd recommend a good quality mid range 6.5" in size...and band pass it to supplement some mid-bass and upper vocals...Don't run any tweeters....with that much power on the front end you'll most likely need to power these with an amp of about 30-50% of the power of the front stage amp.
go with some el cheapo 6.5s on the rear deck, get some little baffles for them and call it a day, the head unit power should work out well... doesn't take much
I ended up going with the Infinity Reference 6.5 component set up front, and polk audio dB 522 coaxial set in the rear. All of them powered by a...
29
606
I’ve tried it in 3 different vehicles and multiple locations. Rear deck is best for me. Unless it’s a midbass I don’t want anything in the rear...
10
761
thetruthc32
thetruthc32
NY
Decipha
slater
    May 2, 2024
slater
    May 2, 2024
