What is a DVC????
Is Dual Voice Coil.. it is a sub that has two sets of inputs and allows greater versatility for wiring.. Like using two DVC subs with a nominal impedance of 4 ohms per Voice Coil can be wired to create a 4 ohm mono load on an amp..or 1 ohm or 16 ohm..if you only want two subs and have one amp they are great.. There are other factor in deciding as well like how much money you want to spend on amps and or subs..You can get more or fewer it just depends on what you want out of your system..
Mike
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
598
Before I started to cut wiring, I would just leave one of the connectors unplugged. Based on your 3rd image, it looks like the wiring was spliced...
Its never justifiable to rush a clean install. Its best to do research for the proper speakers needed and wanted and amplifier to supply for the...
37
6K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
bj4224
bj4224
Houston, TX
adamawayfrommpa
