What is a DVC????
Is Dual Voice Coil.. it is a sub that has two sets of inputs and allows greater versatility for wiring.. Like using two DVC subs with a nominal impedance of 4 ohms per Voice Coil can be wired to create a 4 ohm mono load on an amp..or 1 ohm or 16 ohm..if you only want two subs and have one amp they are great.. There are other factor in deciding as well like how much money you want to spend on amps and or subs..You can get more or fewer it just depends on what you want out of your system..
Mike
bj4224
bj4224
Houston, TX
adamawayfrommpa
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
