poisoned10
I have been having problems with my system and I'm not really sure where the problem lies.
My amp will cut in and out of protect mode with a blinking protect mode light. According to the JL Audio manual that means its either running at an impedance lower than it can handle or the power source is below 8.5v.
I just checked it while it was in protect mode and the voltage was 13.3v. So that leads me to believe that the sub is running lower than 2 ohms. It is a 4 ohm DVC that is wired in parellel to 2 ohms. I've been told that when a sub is going bad that it sometimes will run at a lower impedance than what it normally would. Is this likely the problem? Sometimes it will run for 20 minutes with no problems and other times it will run for 5 minutes.
I've done the big 3, checked all wires (especially the grounds), have gains set properly, checked to make sure amp isnt over heating, etc.
So am I looking at a failing sub or bad amp or combo of both?
Thanks for any and all input.
