What Component Setup Should I Use
james33440
FL
I have several questions. First off, I want to keep my Kicker KX600.4 amp. Otherwise, I would like to get either a Diamond Audio or US Amps Tube Driver 4-channel amp. Also, I have a set of Q-Logic kickpanels that will hold 5.25" components. Not sure if it will hold 6.5" or not.
Okay, now I want to be able to feel and hear my mids as well as my highs. What component set should I go with? Should I use 2 components, 1 in the kickpanel and 1 in the door? Or, should I go with a component set in the kickpanel and a midbass driver in the door? Or, should I just aviod the midbass driver option?
Well, I have narrowed it down to the following companies. However, I am unaware of the positives and negatives of each. What setup should I go with? Also, what brand should I go with? Diamond Audio, Focal, CDT Audio, Peerless, MB Quart, or should I stay with my Kicker Resolution set? Oh, and if I stay with my Resolutions, should I go with the 2 components or one component set and one midbass driver? Thanks.
Well, I think that I will just get a 6.5" component set in the doors unless I can get a deal on midbass drivers in which case I will put those in the doors and the components in the kickpanel. Also, if I get a three way set, would I be able to power them all of one 4-ch amp? Or would I need another amp?
Also, I want good midbass. What midbass drivers or components that have great midbass would you suggest? A/D/S 3 Series was suggested so I will take those into consideration. What about Focal, Dimaond Audio, and MB Quart?
All the speaker brands you mentioned are great, but midbass isn't something that was meant to be felt. If you want to feel it, Audiobahn makes a great high end component set.. but they are pricey and there is cleaner sounding equipment out there.
I’ve tried it in 3 different vehicles and multiple locations. Rear deck is best for me. Unless it’s a midbass I don’t want anything in the rear...
10
886
Crutchfield can tell you what speaker will fit your car. for subs, Image Dynamics and Adire are still around. my last sub i bought was from...
869
I’m sure they will be a good budget setup. I think they will lack some midbass but door treatment is super important so definitely be sure to do...
Sound deadening and door preparations are key to getting the best results towards more SQ oriented within the vehicle, as well as speaker locations
james33440
james33440
FL
bri487
    May 18, 2024
    May 16, 2024
