Again, if what you suggest were true, changing the direction you fire your subs would make no audible difference. And yet it does...ok nvm it was too time consuming just look at this
now imagine that signal reverberated hundreds of times because of the environment of the car being so small and it would be very hard to find big areas of interference. In larger rooms and home theater systems, this problem is more prevelant because of the increased distance the waves travel and reverberate and decay. this also means that interference is more prevelent at lower volumes ie: less and less powerful reverberation.
like i said, I HIGHLY doubt the difference i was experiencing was due to acoustic interference, it was just way too big of a difference, i'm talking about like "something is fvck up with my system" difference. It was probably due to the polarity like i said. and the reason it sounded better when i inverted it was more likely because the airspace for the 13 was too small... and that would also explain why it sounded even better after i added the extension.Again, if what you suggest were true, changing the direction you fire your subs would make no audible difference. And yet it does...
no you are not, however the above proposed setup is over-doing it a bit, and pointless for the goals he is statingA kid in my class (yes I'm in highschool)said he wants two 10s, two 12s, two 15s and a 18...
10 for the kick, 12 for the punch, 15 for the boom and 18 for the slap he said...
I just laughed.
I knew mixing sub sizes wasn't a great idea.. after reading all this I kinda think I understand why..
If you mix sizes, the different subs will cancel each other out, making it seem like there is less subs there?
I'm not sure if I'm understanding this..
That may be, but that still doesn't explain away the issues caused by multiple sized drivers running the same frequency band.like i said, I HIGHLY doubt the difference i was experiencing was due to acoustic interference, it was just way too big of a difference, i'm talking about like "something is fvck up with my system" difference. It was probably due to the polarity like i said. and the reason it sounded better when i inverted it was more likely because the airspace for the 13 was too small... and that would also explain why it sounded even better after i added the extension.
no no i'll admit that, it was a dumb setup choice I made out of ignorance...but it did NOT sound bad or have significant cancellation problems... i mean seriously, even epoxy could not hold my rear-view mirrior on, my dask cracked from flex(also probly weakend from age and sun, but def. cracked during music, and the brackets on the back window broke and shattered my back window. (and before you go //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif the back window is connected very poorly with basically 2 bolts.)That may be, but that still doesn't explain away the issues caused by multiple sized drivers running the same frequency band.
Ive given reasons why such a setup would yield notoriously poor results. Can you give a logical reason as to why someone, who understands what they are doing, would even attempt/require/want multiple sized subwoofers for their subbass? Is it so hard for you to say 'wow I was being a dumb ***, glad Ive learned since then'...? Instead you have to come up with every jack *** reason you can think of why you couldn't possibly have built a truly laughable sub stage. You have 20 highschool friends that tell you that you had no interference. Well you've had alot more people than that here on this board, enthusiasts to fanatics, who have told you that no matter if you thought it sounded 'good', or all your homeboys thought it sounded 'better' than someone else's, the system design had elementary flaws that to the knowledgeable observer would clearly indicate the designer/builder had some fundamental errors in his acoustical theories.
As for acoustic interference and its impact, it can make drastic changes if you want to discuss localization. Borrow someone's SPL meter, move the mic around in your cabin, and then come tell us why CGt didn't apply and 'fill in the gaps'.
You have referred to electronic cancellation more than once now. How are you suggesting this affected your stereo system?
and something else, i'm still not seeing a bassis for why Multi sup setups have more interference than same sub setups?That may be, but that still doesn't explain away the issues caused by multiple sized drivers running the same frequency band.
