a d34 (other yellowtop) is 55 ah~ how many aH is a standard car batt...? a g31 or 2400 or the like even?
alot more aH than the hawker ones thoughgod, them little bastards are expensive!
Those are both group 31 batteries.the kinetik 2400 was not the largest batt the 3200 was much larger, but they were a limited stock and are now all gone
for reserve capacity ( daily driving ) a 2400 kicks major butt , but on discharge rate at stinger sp2150 ( oddesy 2150 same batt ) does a bit better and i was also told a group 31 is right up there with a 2150,
A 2150 is a group 31 as well as the 2400. So saying a "g31 over the 2400" makes no sense. If you are talking about Optima's group 31 battery, I beleive the model # is D31A.ill deff go wit the 2150 or g31s over the 2400. way better batt and has proven to be, in most cases. but nsb90s are juss some insane batts for the money
when someone says g31, im sure everyone knows that they are refering to optima 31A. cmon nowThose are both group 31 batteries.
There are different group standards for how batteries are categorized
If a battery falls in the following specs, its considered a group 31.
Group 31
Amp Hours: Between 95-125 Amp hours
Volts: 12 volts
