What amp should I use with a Focal 46" Subwoofer?
  • 4
I have Focal Utopia 3 way speakers from 12-14 years ago. So I want to go with a Focal Subwoofer. I'm thinking the Focal K2 46 KX (100 to 1000 watts RMS. 2000 Max). I'm just thinking using this one cuz it's the biggest. I have a Macintosh amp for the 3 ways & wanted to use a Macintosh for the Sub. But does a Macintosh amp put out enough power? From the ones I've seen they don't. So what's a top of the line amp I can run my sub with? Thanks Bill
it mostly depends on the enclosure and output expectations. a huge enclosure will be more efficient and require less power.
this is the sub, correct?
Focal K2 Power™ 46 KX 4 18" subwoofer with four 1-ohm voice coils at Crutchfield.com
it's 18", not nearly the biggest sub available. with four 1 ohm coils they can be wired in series for a 4 ohm mono load that a Mac amp could run (bridged) but it will be hard to find that much power. or you can series/parallel for a 1 ohm load that most sub amps can drive. if it were me, an Audison LRx 1.1k would be my choice.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
Have you check to see if the prefab would fit...
13
For the sub you want to run.. The 700.1 will be more than enough power and enough Head room for that sub. For the Price? And the sub you are...
13
Your skar amp will catch on fire if you go full power?
I'll suggest a JP8 amplifier. I believe you can wire your sub to 2 ohm. It's Dual voice coil 4 ohm, correct? JP8 @ 2 ohm does 900 watts.
32blownhemi
32blownhemi
Ventura County, CA
keep_hope_alive
    May 12, 2024
Brendon Jenness
    May 11, 2024
