(1) Diamond Audio D310D4Needed - (Sub Make and Model Number) please be exact eg. instead of (Type-r) (please say Alpine Type R SWR-1242D) and how many
SQLwould you like high spl (desired SPL??please give) or extened low-freq. bass
Width 3' 2-3/4"your approx. box dimenions or largest possible.
Slot port (1)Ported or sealed or bandpass. (if ported, slots or round ports? and how many you want)(desired Tuning Freq.)
(Dual 4ohm VC) Wired to 2 ohmsSubwoofer Wiring.
Would like ownWould you like to follow comp recomendations for box type and size? or do you want your own?
Quit while you're ahead. If you were truly designing boxes, you wouldn't give someone a dimension of 8.8 inches. Plugging numbers into a program and getting theoretical numbers does NOT equate to enclosure design.Port: 11.5 (H) x 3 (W) x 8.80602924524359 (D)Port Materials.
2 - Sides - 11.5" (H) x 0.75" (thick)(W) x 8.26696343779791 (D)
Tuned @ 37Hz Cut-Off Freq. - 29.94Hz
always remember to round-off port edges.
It's either something quite expensive such as SpeaD or LEAP, or something cheap and rudimentary like ProBox. Either way, he's just plugging in numbers and isn't giving out dimensions you can cut without a CNC router.I'm assuming he is using LEAP.
U musn't know math to well if you believe that I would say "cut" 8.8" ........8.8" is from edge to edge of the port. placing the wall internally shortens it by 0.75". and I am sorry "I" don't round off the number for you. + why not use a table saw to make that cut. + Encosure is designed for the sub. designing it by "the car" isn't smart. you just need your max dimensions that you want it to be. Information from graphs are VERY accurate. I don't just punch in. you want it proper ill spend the time.Quit while you're ahead. If you were truly designing boxes, you wouldn't give someone a dimension of 8.8 inches. Plugging numbers into a program and getting theoretical numbers does NOT equate to enclosure design.
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif :laugh: //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif @ you telling me how to design an enclosure. Look in sig for a sample bud, I've had a fair bit of practice.U musn't know math to well if you believe that I would say "cut" 8.8" ........8.8" is from edge to edge of the port. placing the wall internally shortens it by 0.75". and I am sorry "I" don't round off the number for you. + why not use a table saw to make that cut. + Encosure is designed for the sub. designing it by "the car" isn't smart. you just need your max dimensions that you want it to be. Information from graphs are VERY accurate. I don't just punch in. you want it proper ill spend the time.
