Wall Build - 4 18's - Dodge Ram
avs20
I decided to go ahead and build a wall and add a 4th MJ-18. I started the build today and got quite a bit done.
First off I want to thank BrianChia for the plans. It wouldve taken me a year to do what he did in a couple days. The plans he sent me are absolutely amazing. He sent me 15 different pages of plans covering EVERY angle, and also sent me 2 cut sheets. Thanks again Brian.
Also, the 4 MJ's are temporary. Hopefully by the end of the year I will have my 4 18" BTL's running off 8k watts.
So here it is. Im mocking it up outside of the truck due to the angles etc. It's much easier to correct outside of the truck rather than inside! Let me know what you think! If I can remember(I always forget) Ill bring my actual camera into the garage and not my camera phone.
Brian, are the braces on the side and front necessary? It doesnt seem like they would do much honestly, that's why Im asking:)
They are not completely necessary, but large unsupported or unbraced panels have a greater potential to flex and/or resonate. Especially with 8kW and 20mm+ of excursion.
Bracing like that splits the panels into smaller sections which reduces the possibility of any flexing or box losses.
Yeah need bracing on the large panels . I would put some 2 x 3's on the outside if you have room
Yeah, I know you need to brace large panels, but that particular panel is only 30". I think I might brace it differently. Im not sure yet. I already have the pieces cut so I might just say to hell with it and do it that way:)
avs20
avs20
Frisco, TX
Rashaddd
michigan born
    May 14, 2026
michigan born
    May 14, 2026
