Wall Build 2 Rl-p 18"s
oxsign
No Affiliation
6,046
34
Orlando, FL
OK, so after many months of procrastinating, I finally got around to building it. Now keep in mind when looking at these pix, it's far from done. This was a quick build to make it to a show. I still have a lot of the "beauty" trim to put up, wires to clean up, and tuning to do to the amps. So with that being said, it's on to the pix!!!!!!!!!!!!!!!
This was my old setup
The new build
My door panels with 2 MAW 6.5"s & 2 Fusion Power Plant Tweeters to each door
Be gental with the remarks & comments, lol. I know it's not a "true" wall, but I go through so many ideas that I wanted to be able to take it out later, lol.
ewwwwww! lol j/k, still a great sub.. how did that fading happen?
(also, let me know if you want to add a third RL-p 18 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif )
looks it's gonna sound pretty sick. i have a RLp 15 for a few years now, and that aluminum cone is pretty easy to ding up. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Nice build. How do you like the Mach 5 components? I was thinking about getin some to run wit my MAW-15's
The MAW's sound really good. They get nice and loud. A great buy for the money.
***** about that sun faded/corroded cone :/
The fading does really ****. I'm trying to figure out a way to make them match, lol.
I would seriously consider it if it was a D4, LOL. The sun is what caused the fading. I used that sub for about 8mths while the other one sat in my room.
Ya, my compressor fell on it, and caused those ugly dings on the black one. //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
As for the sound, well it does get very loud, but it's tuned to about 28hz. So it's a low end monster. EVERYTHING shakes in here, lol.//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Looks like no real bracing in the box. Does it flex much? RL-P's are nice subs, but do dent too easily. Should be loud and sound good...
You can't really see it in the pix. Also the fact that I didn't really get any pix of the bracing, but it's got a 4x4 going top to bottom, side to side, and front to back. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Not too bad, but like you said you want to be able to take it out and what not, so I understand that.
I betcha it gets loud and that is all that matters.
Got to admit, you might be the only person I have ever seen run Infinity amps.
Good job!
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
867
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
These are the tweeters in going to use in my truck. Beefy little guys just going by weight. Probably not the best for a car audio setup, but I'll...
63
8K
oxsign
No Affiliation
oxsign
Orlando, FL
MikeyB
Brendon Jenness
    May 8, 2024
    May 8, 2024
